Fitted fuel tank under the glare shield. My installation required AN3-11A bolts on the tank straps instead of the AN3-15A's called out in the prints.
Drilled holes in the top of the rudder blocks to install grease fittings (M8-1.0). Put two in the center block, one for each opposing rudder assembly.
Put cushions on the seat sling to check for a good position of the rudder pedals. I decided moving them aft about 4" fit me well.
Updrilled holes and fitted the rudder pedals. I mounted the outside blocks first and then placed a straightedge against those to set the center block for drilling. Pedals move smoothly, just snug enough that they stand up on their own. They should be floppy with a little use and wear.
